Brake HELP!!!
Old Feb 13, 2015 | 11:37 AM
kickass92z's Avatar
Car: 92 Z28/86 T/A/98 R/A T/A
Engine: 355,355,LS1
Transmission: T-56,700r4,T-56
Axle/Gears: 3:73,3:42,3:42
Brake HELP!!!
So when I bought my 92Z it had been wrecked, and the rear end had been changed with an 85 disc rear, and never has had e-brake. I found the right rear after years of looking. I pulled it apart last night and its had lots of water in it, so it's junk. The brakes however are all there with e-brake cables.
My question is will the PBR aluminum calibers and rotors just bolt up to the 85 rear?
Can I change the mounting brackets and make them work?
Or, should I pull everything out of the 85 rear, which is all good stuff and 28 spline, and put it in the 92 housing to maintain the brakes??
Thanks in advance!!!
Old Feb 13, 2015 | 11:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brake HELP!!!
Yes. The following link will serve as a guide:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
You'll find more info below, including info about master and combination valve:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 13, 2015 | 12:24 PM
kickass92z's Avatar
Engine: 355,355,LS1
Re: Brake HELP!!!
FREAKIN AWESOME!!!! I LOVE THIS SITE!!!!
THANKS!!!!
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
