e brake issue.
Old Feb 19, 2015 | 06:28 PM
sorrys70's Avatar
e brake issue.
i cant seem to get a straight answer on this one. I have a 1991 rs and i recently put a 9 bolt in my car with cast iron calipers. it used to be drums so i have to change over the cables. does anyone have this swap done? i need to know what cables i need and which parts i need. any help would be really appreciated
Old Feb 20, 2015 | 07:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: e brake issue.
Part of the issue is that your 91 should have a self-adjusting parking brake whereas earlier cars were equipped with a tunnel-mounted adjuster. Take a peek to verify what you have.
One solution is to swap to PBR's. (You'd have better brakes and an easy solution to the parking brake cable problem.) There are only two lengths for PBR's: 1st design, 1434 mm and 2nd design 1460 mm. According to Ed Miller, the longer cable was designed for cars with no adjustment provision in the tunnel. I used the shorter one in my 85 because of the tunnel adjustment.
Some info below, along with a pic of the adjuster, that might prove interesting:
https://www.thirdgen.org/forums/brak...djustment.html
JamesC
Old Feb 22, 2015 | 10:31 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: e brake issue.
I did the swap you are contemplating years ago on my 90 RS 'vert. I did swap the parking brake from an earlier (pre 89) car so it has the parking brake adjuster JamesC describes. I also bought new cables for each side. For some reason I had to cut off a spiral wound shroud from around the cable at the end where it mounts to the calipers. I used a dremel tool and a fiber-reinforced cutoff wheel. Be careful and keep it cool while you cut off that spiral of metal since the cable inside is covered with plastic which will melt if overheated. I had a lot of trouble with sealing one of the brake lines for some reason I can't recall. I was leaking brake fluid and the brake switch on the combination valve kept indicating brake failure (correctly). Once I got the brake line properly sealed a stiff push of the brake pedal re-set the brake switch.
I agree swapping to the PBR brake calipers would be simpler, but costlier. You'd also need the proper backing plates, parking brake cables, brake lines, and rotors. I can't recall if you can get by by using your existing backing plates, but simply swapping them to the opposite side and re-drilling them to mount the PBS calipers. Someone else will have to confirm this.
Lon
Old Feb 23, 2015 | 07:25 AM
JamesC's Avatar
Re: e brake issue.
The 9-bolt PBR backing plates can be swapped as you mention (though I personally wouldn't recommend it) but not the Delco-Moraine—at any rate, the Delco-Moraine backing plates wouldn't allow the mounting of PBR's.
JamesC
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
