Cant Get Fluid
Old Apr 12, 2015 | 03:49 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Cant Get Fluid
I did everything to the brakes I cant get brake fluid it seems up to the front brakes you take out bleeder screw an very little comes out these are manual any ideas please Help. THANKS.
Old Apr 12, 2015 | 04:11 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Cant Get Fluid
I bleed the brakes each time I open the brake line to install the new caliper.
Not waiting until both are done.
I don't know the procedure when that is done.
Here's how to bleed the front brake calipers on my car.
Fill the reservoir on the master cylinder watching it closely as you lose fluid, keeping it topped off.
Keep the cover on the brake master cylinder reservoir on tight when pumping the brake pedal. Have someone get in the car. Have him pump the breaks a few times holding it down at the end ,then you crack open the bleeder Zerk nipple enough to let some fluid out. Then close the nipple and have him do it again until the pedal is nice and tight with no air bubbles in the fluid coming out of the nipple.
Do not let the master cylinder run out of fluid.
Don't forget that brake fluid will eat paint.
Use a rubber hose on the end of the nipple going into a clear container as you do this.
Don't let him lift the peddle untill you have the nipple closed.
Old Apr 12, 2015 | 07:32 PM
Re: Cant Get Fluid
No fluid comes out = blocked lines
"Manual" doesn't matter.
Suspect the rubber hoses. They fail by rusting on the inside, and closing up the teeeeny tiny hole that started out being there. Just replace em, they're cheeeeeeep.
Should be able to bleed em by just opening the bleeder and letting the fluid dribble out, and waiting until clean fluid appears. No effort of any kind required. Just let the work do itself.
Old Apr 12, 2015 | 08:08 PM
Engine: TBI,5.0
Re: Cant Get Fluid
[QUOTE=
Should be able to bleed em by just opening the bleeder and letting the fluid dribble out, and waiting until clean fluid appears. No effort of any kind required. Just let the work do itself. [/QUOTE]
OK, but what fun is that........
Old Apr 13, 2015 | 07:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Cant Get Fluid
X2.
JamesC
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
