Brake pedal travel with LS1 MC and booster
Old Apr 20, 2015 | 10:45 AM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
Hi guys, I just completed the LS1 MC and booster swap and started my car for the first time since the beginning of winter last year. Its been so long since I last drove my car that I cant remember how much travel the brake pedal normally has. After this swap, it could be just me, but it seems that I only have about 1.5" or 2" of brake travel. Can anyone tell me if this is normal?
Old Apr 20, 2015 | 12:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Brake pedal travel with LS1 MC and booster
Possibly, the LS1 MC has a larger bore, which in general reduces the pedal travel. However, the stock MC is a quick take-up design, which will also reduce pedal travel.
But, if the front brakes have been upgraded to a non-low drag design, then the quick take-up isn't required. And won't have much affect on the pedal travel.
RBob.
Old Apr 20, 2015 | 12:56 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
I can tell that when I reach the end of the stroke, its not due to the pads pressing on the rotors, its hitting the end of the MC or booster stroke. I just need a reference to what the max stroke at the pedal is supposed to be.
Old Apr 21, 2015 | 06:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Ahh, wasn't thinking along those lines. I did find this in the '92 FSM:
Brake pedal travel (disc/drum) (nominal): 2.25 inches
Brake pedal travel maximum with 100 lbs force applied to the pedal with ignition off and vacuum assist depleted.
A little confusing to me as they state it as 'nominal' and then as 'maximum.' This would also be with the system bled and sealed up.
RBob.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Stauf
Brakes
Sep 1, 2015 06:15 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
