Still have a spongey pedal. suggestions
Old Apr 27, 2015 | 04:33 PM
rads84n94camaro's Avatar
Car: 94 Camaro RS. 84 Z28 350 T5
Engine: V6 & V8
Transmission: Automatic & Manual
i have the ILE setup all around on my 84 camaro, ( swapped rears with disc brakes) new mater cylinder for the 4 wheel disc brakes setup, benched bled, bled all the lines, but still have a spongey pedal. any suggestions on what i should do next? I do have the correct proportioning valve. Ive read that sometimes the proportioning valve can trap air in it? does this seem like it could be the issue? The warm weather is here and hopefully i can get the issue resolved soon so i can get back to work on restoring my 71!
Old Apr 27, 2015 | 05:29 PM
jcat's Avatar
Car: 96 Impala 84 berlinetta
Transmission: 4speed auto
Re: Still have a spongey pedal. suggestions
with the changing a lot of fluid is lost. start with the right rear and left rear then the right front left front last .. then repeat using a hose on the bleed fitting so no air can enter .. DO NOT PUMP PEDAL TO FLOOR ONLY HALF WAY...until high and hard. also you can do this with engine on so you get more pressure to speed up the bled..
soft pedal is the air. you can get soft pedals with worn rotors and pads also.
Old Apr 28, 2015 | 06:25 PM
Engine: V6 & V8
i bled all four corners starting with the furthest point just as youre supposed to do, also the pads and rotors are new. when bleeding them the fluid came out with any air in the lines after multiple pumps. Any other ideas?
Old May 3, 2015 | 02:31 PM
jcat's Avatar
some times the air with changing all these parts is hard to remove. try bleeding again. have engine running you will get more pressure. have long clear hose on bleed fitting. this way you can see any bubbles.
Old May 6, 2015 | 09:08 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Did you bench bleed the master cylinder before installing it? If not, you can have a rough time getting the system bled correctly.
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ironbmt
Sep 27, 2015 06:00 AM
