Part number for 3rd gen rear disc caliper rebuild kits for iron caliper
Old Jun 7, 2015 | 09:21 PM
SOCAL-Z's Avatar
Car: 87' IROC
Part number for Dorman d351576 rear caliper rebuild kits, work well.
Old Jun 8, 2015 | 09:33 PM
SOCAL-Z's Avatar
Car: 87' IROC
Re: Who sells a rear caliper rebuild kit that fits a 87iroc?
Contacted Centric and found 14362008 to be the correct rear caliper rebuild kit# from them. Also work well for the iron rear caliper.
Old Jun 14, 2015 | 07:49 AM
SOCAL-Z's Avatar
Car: 87' IROC
Found that both kits were correct. My calipers had the metal rings from the old seals stuck in the dust seal mounting area(rubber seal had seperated from the metal ring). Looked just like part of the caliper casting. I removed the metal rings with a small screwdriver and a hammer. Both kits worked well on the iron rear calipers and took no time to rebuild. Hope this info helps
someone.
Old Feb 5, 2019 | 03:11 PM
skinny z's Avatar
Re: Part number for 3rd gen rear disc caliper rebuild kits for iron caliper
If the PBR calipers are also common to the 4th gen, Hawks has these:
https://www.hawksmotorsports.com/98-...r-rebuild-kit/
Old Feb 6, 2019 | 06:59 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Recall kit for the delco moraine rear brakes. Includes everything needed for a caliper rebuild with the upgraded pistons that fixed some issues. Not sure if it's still available.
Part Number: 18019028 from GM Parts Direct, listed as "Actuator" and included parts for both rear calipers, pistons, springs, seals, etc.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
