Run off the road - need to upgrade brakes
Old Jul 12, 2015 | 05:24 PM
thorflynn15's Avatar
Car: 1987 IROCZ28 Camaro
About 20 minutes ago I was cruising down the highway around 65-70 and had a riced out honda civic lock up his brakes in front of me. Car didn't slow down nearly quick enough and I had to take it into a ditch. Needless to say I don't want to have issues braking when I have my girlfriend or family in the car, and the last thing I want to do is rear-end some ******* when my car has no airbags. Anyone have any upgrade recommendations?
1987 IROCZ-28 Camaro
305 700R4
Going to throw in a 406 with a 5 speed in a few months
Thank you for your help.
Old Jul 12, 2015 | 06:17 PM
Re: Run off the road - need to upgrade brakes
www.bigbrakeupgrade.com on the front; the LS1 setup (the Vettes are nice and all but the LS1 works just as good, just isn't as "cute")
A LS1 (98-02) complete rear end assembly in the rear
Old Jul 18, 2015 | 09:51 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Will the ls1 brake set up fit 15 inch rims?
Old Jul 18, 2015 | 12:15 PM
AFAIK no. Do the math: a 13" rotor (6.5" from center to edge) inside a wheel that's 15" (7.5" from center to inner edge of tire), minus the height of the wheel bead, minus the thickness of the wheel, minus clearance between the caliper and the wheel, minus caliper thickness, minus clearance from rotor to caliper...
Why would anybody want to run those old pizza-cutter things that you can't buy anything like modern competitive tires for anymore, anyway?
Old Jul 25, 2015 | 11:14 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
https://www.thirdgen.org/forums/brak...-ultimate.html
I've had extremely good success with the combo above. The price to value can't be beat. Only difference for your car would be that the front and rear brake pads would be the same part (D-154HD)
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
