E-Brake adjustment question
Old Jul 13, 2015 | 07:39 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hows it going guys. I have a question. I tightened up the nut at the equalizer and removed the slack. Now as I pull on the e-handle, there is very little resistance and the brake does not hold the tires. The tires keep spinning. The E-handle travels all the way up. Should there be tension at half way up on the e-brake handle? Thanks.
Old Jul 17, 2015 | 07:23 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: E-Brake adjustment question
FSM sez , after adjustment , 14 clicks from full release should lock the wheels. you MAY have a cable issue. id check that first . also lube every where the cables run
Old Jul 19, 2015 | 02:09 AM
Yeah thanks for the help bro. I have the service manual. Remember? I got busted for selling them? Anyways, I found the problem. The screw that pushes the piston was bad.
Old Jul 19, 2015 | 03:20 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Yeah thanks for the "help." I have the service manual. Remember? I got busted for selling them? Anyways, I found the problem. The screw that pushes the piston was bad. Have a good night.
glad i didn't try to help you... i prefer to be told "thanks for the help" when i try to help someone out, not "**** you, i know what i'm doing"...
Old Jul 27, 2015 | 01:21 AM
Did realize that what I typed was re worded by my phone. Thanks for pointing that out man.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
deracer
Apr 11, 2016 12:04 AM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
