Rotors: Blank -vs-Cross drilled -vs- slotted - The Good, The bad, The ugly
Car: 90 Formula / T-tops
Transmission: MD8
Found this article, found it interesting. The article applies to street brakes, not racing. The author doesn't even like ceramic pads. Curious what other think for street brakes.
He is saying just go with blank rotors, there is little if anything to gain from slots/drilled.....
http://automotivethinker.com/brakes-...d-and-warping/
This guy compiles a lot of quotes from several sources:
http://www.6crew.com/forum/showthrea...d-and-the-ugly
Nice article on servicing your brakes
http://www.motor.com/magazine/pdfs/062007_09.pdf
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Rotors: Blank -vs-Cross drilled -vs- slotted - The Good, The bad, The ugly
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I`m pretty sure this guy has NEVER put a rotor on a brake lathe, common` this is just a big load of BS here....
What a crock of
So what really happens when the rotor is “warped”?
When you’re on the brakes and there’s a pulsing sensation or vibration, we typical call this situation warped rotors. Surprisingly, I personally have never seen a rotor that actually has physical distortion. I have even placed a dial indicator on so-called warped rotors to find that they have no run-out what-so-ever.
What does happen is that the layer of pad material on the rotor surface builds up unevenly, and the metallurgy of the rotor can change states. The layer of pad material on the rotors surface, if it is unevenly distributed, will create hot spots. If these spots get hot enough, it can form cementite in the rotors metal – a rough iron carbide formation that creates a lot of friction, but is terrible at dissipating heat. The cementite formation can get so bad and cause so much friction that even when you are off the brake pedal completely, because your pads are always in contact with the rotor ever so slightly, it can create a vibration when driving normally. I have even mistaken this vibration as my tires being out of balance.
What a crock of
I had a CASC guy tell me that they experimented with all kinds of rotors in roadracing, and they found that the Delco solid blank rotors held up the best.
85@IRocZ
19
Dec 25, 2015 09:33 AM
trackbird
Nov 25, 2015 01:44 PM
LiquidBlue
Nov 9, 2015 10:24 PM
