Brake Line Sizing
Old Nov 4, 2015 | 08:03 PM
smnichol86's Avatar
Car: 1986 Camaro IROC-Z
Engine: 383 Stroker
Axle/Gears: 4.10
Brake Line Sizing
Hello all,
I am performing a rear drum to disc swap on my car and have decided to replace all of the lines as well. I've found that the front-to-rear line is 6mm, but I cannot find any 6mm tubing anywhere. I can up it to 1/4 inch tubing, but I am uneasy about the connection to the rear brake hose since that will expect 6mm. Will 1/4" tubing connectors mate well with 6mm? If not, what are some options for a work around?
Old Nov 4, 2015 | 08:21 PM
Re: Brake Line Sizing
6mm tubing is available at EVERY parts store.
Just walk into ANY AZ, Advance, Checkers, NAPA, Pep Boys, whatever; and ask to look at their sticks of brake line.
¼" & 6mm are pretty close, but not close enough for most tools. (6 vs 6.35mm) I'd stick with the right stuff if possible. Especially since your car's ENTIRE brake system is plumbed in metric.
Old Nov 4, 2015 | 08:48 PM
smnichol86's Avatar
Engine: 383 Stroker
Axle/Gears: 4.10
I am trying to price things out as I go with online searches, I guess I was just not searching the correct keywords to find pricing on 6mm tubing on the parts store's websites so I just assumed that they didn't have it.
Anyway, thanks for the advice, I'll stick with what's there. Any advice on which place might have the best selection of various fittings/adapters? The lines are all iso bubble flare, but the prop. valve I'm looking to install came with 45 double flare fittings, I'd be interested in swapping those out for bubble.
Old Nov 4, 2015 | 08:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Have you considered buying the pre bent replacement lines? Not terrible expensive and a lot less work
Old Nov 4, 2015 | 09:02 PM
smnichol86's Avatar
Engine: 383 Stroker
Axle/Gears: 4.10
Yes I have, so far I'm seeing that the amount of money I save by the DIY method is almost completely offset by the cost of the tools that I would need to purchase. That is why I would be interested in finding some fittings that were iso bubble flare for my prop. valve so that I won't have to buy the pre-bent lines only to end up cutting and flaring one end of them.
Old Nov 4, 2015 | 09:07 PM
Online only works just so far.
Sometimes, at some point, for some things, ya just gotta get off yer keyboard and step out into meatspace. Sux, I know; but, if it wasn't just a tiny bit tuff, it wouldn't be worthwhile, eh??
Go walk yer physical carcass physically into yer local physical brick & mortar corner AZ etc. and ask em to let you look at their bin of sticks of brake line. I think you'll be pleasantly relieved.
Old Nov 5, 2015 | 02:50 PM
AmpleUnicorn88's Avatar
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
They make aftermarket stainless braided lines. Russell sells them, and there are others. I believe the brake lines I bought to replace my front brake lines were russell, and they are pretty nice. They won't kink, and they fit a little better. I paid probably about $85 after tax and everything to replace my front brake lines and hoses with the stainless braided lines and the fittings.
willyjoejr
Oct 19, 2015 05:31 PM
dwisti
Oct 18, 2015 03:50 PM
azscottd
Carburetors
Oct 16, 2015 10:05 AM
knightinblackar
Brakes
Oct 13, 2015 05:26 PM
okfoz
Oct 9, 2015 08:49 AM
