Brake Warning light Question
Old Oct 16, 2015 | 09:54 PM
willyjoejr's Avatar
Car: 1985 T-Top RS
Transmission: currently a T-5
I am just finished doing a 350 swap on an 85 Z28. I did some work on the brakes, bleed them (rp,rd, fp, fd) and set the emergency brake. The brake warning light came on after I set the emergency brake. The light stays on when the emergency brake handle is down, so you can drive. when I park it and brake handle up the light goes out. Does them mean the emergency brakes are not completely releasing?
Old Oct 19, 2015 | 05:25 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
A Walk In The Park
If the parking brakes were not releasing you would overheat them.
If you’re vehicle aware you hear and/or smell and/or feel them.
Therefore most likely the light is not operating the way it’s supposed to.
From your description it is doing the opposite of normal.
Check the wire going to the parking brake.
Temporarily disconnect it from the parking brake handle.
When you do that does the light go out?
Happy Racing !
They Want To Put HOW MANY Cameras In My Car Next Year?!?!?!
Old Oct 19, 2015 | 05:31 PM
willyjoejr's Avatar
Car: 1985 T-Top RS
Re: A Walk In The Park
Thank u for ur response. I backed off the emergency brake a couple of clicks and the light is now off.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
86z89iroc
Oct 5, 2015 01:04 PM
ndndndnd
Sep 28, 2015 08:00 AM
dbrochard
Sep 25, 2015 04:56 PM
///DAN///
Sep 25, 2015 02:15 PM
