Big brake upgrade.
Old Jan 3, 2022 | 11:39 AM
  #51
Ponch85rs's Avatar
Car: 1987 Chevrolet Camaro Sport Coupe
Axle/Gears: 3:42
Re: Big brake upgrade.
I am in the middle of this right now. I am having a problem with the emergency brake shoe clearance.
I cannot push the driver side axle in far enough to get the C-slip in becusas4e the hub of the axle is hitting the e-brake shoe. This doesn't seem the be a problem on the passenger side because of how the ring gear carrier is designed.
Has anyone run into this?
TJ
Old Jan 3, 2022 | 11:48 AM
  #52
BBU.COM's Avatar
Top Answer: 1
can you remove the shoes and get the clip in? reinstall the shoes after the clip is in ?
Old Jan 3, 2022 | 11:52 AM
  #53
Ponch85rs's Avatar
Axle/Gears: 3:42
Unfortunately not. Once the c-clip is installed, the clearance between the hub and the e-brake shoe is so tight, you wouldnt be able to slide the shoe in (i tried) or even bale able to install the ebrake show retaining clip.
Old Jan 4, 2022 | 11:26 AM
  #54
Ponch85rs's Avatar
Axle/Gears: 3:42
Well, I had the backing plate on backwards. Once I switched them, and bend that e-brake shoe ever so slightly, i was able to sneap the c-clip in. AND get it back out, which is key. Chalk this one up to not paying attention.
Old Jan 4, 2022 | 03:08 PM
  #55
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Good to know it worked out. Whenever you're finished and ready to show it off, be sure to post pictures. Everybody LOVES pictures!
1Aauto
Sponsored Vendors
Jan 25, 2017 02:44 PM
1Aauto
Sponsored Vendors
madsv1000
Jan 29, 2016 10:35 PM
mike0brien
Jan 12, 2016 10:08 PM
