Universal booster and master
Old Feb 16, 2016 | 05:02 PM
Slayze's Avatar
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
I am redoing most of my car before I put the new 383 stroker in and I will be running new break lines. I have been looking at possibly doing something with the booster/master. My question is has anyone used one of the universal set ups? If so was it a pain? Alot of modification? Here's a link to one I just looked at from summit.
http://m.summitracing.com/parts/rsd-...BRkaAjvo8P8HAQ
Old Feb 16, 2016 | 07:15 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Universal booster and master
I'm considering getting one of those Baer Remaster master cylinders. I really dig how they look. Just don't know enough about them yet to pull the trigger.
Old Feb 16, 2016 | 10:51 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Originally Posted by Slayze
I am redoing most of my car before I put the new 383 stroker in and I will be running new break lines. I have been looking at possibly doing something with the booster/master. My question is has anyone used one of the universal set ups? If so was it a pain? Alot of modification? Here's a link to one I just looked at from summit. http://m.summitracing.com/parts/rsd-...BRkaAjvo8P8HAQ
You must separate the link from the paragraph above or next to it.
Give the link some space and it will work.
Old Feb 17, 2016 | 08:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Stock M/C bore is 24 mm, the one you linked to is 1-1/8" (28.6 mm). This will cause a 30% decrease in brake force with the same pedal force.
Then the booster, it is a 7" unit which is worthless for providing any boost. It also appears to be a single diaphragm unit, with our stock one being a 9" dual diaphragm unit.
All-in-all you would be lucky to be able to stop the car with that setup.
RBob.
Old Feb 17, 2016 | 09:14 AM
Slayze's Avatar
Car: 87 Trans Am
Thanks for the info and reply. Definitely don't want less stopping power.
'91CamaroRS
Apr 12, 2024 11:36 AM
Digs_do_it89
Apr 11, 2016 12:26 AM
nuggie
Feb 12, 2016 08:02 PM
GraphMan
Feb 12, 2016 03:07 PM
