Can't get cotter pin into holes on spindle
Old Feb 22, 2016 | 10:27 PM
'91CamaroRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
My left front wheel bearing went out,so I replaced them. I replaced to races too,and made sure they're all the way in. I replaced the seal too. I put it all on the spindle,and ran the nut down. I made sure to push the rotor all the way back while I got the nut as far down as possible before it got snug. My issue is I can't get the castlated nut down far enough to get the holes in the spindle to come into view. I've tried spinning the the rotor while turning the nut,but that didn't do a single thing. What's my problem?? This is driving me crazy!
Old Feb 23, 2016 | 05:41 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: Can't get cotter pin into holes on spindle
Sounds like you don't have the races driven all the way in the rotor or your bearing mating surfaces on the spindle are galled keeping the bearings from sliding all the way on.
Re-check the races, slide each bearing on the spindle and make sure their going all the way on, also double check that you were sold the correct bearings and seal. Make sure the seal goes all the way in flush with the back of the rotor.
Now's the time to check/replace the other side as well......
CEF FUR
Exterior Parts Wanted
Feb 14, 2016 06:19 PM
mr_han_solo
Feb 11, 2016 11:49 PM
tcrisp
Feb 10, 2016 04:57 PM
9manastacio
Feb 10, 2016 06:08 AM
L-Train8
Feb 5, 2016 03:30 PM
