Rear GTA wheels on the front after LS1 brake upgrade
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
I have a question about Switching the rear and front GTA wheels after upgrading to LS1 front brakes. Can someone corroborate what has been said in this quote from Mike_c?
Re: gta rim question
Quote:
Originally Posted by mike_c
I have my rears on the front and vice versa. The car looks much better this way. I didn't need any spacers on the front, but I have LS1 front brakes which widens the front track a bit, but by how much I don't remember.
The track width is increased the width of the rotor, about .22 to .25 inches
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Rear GTA wheels on the front after LS1 brake upgrade
i run rears on all 4 corners of my car- with the matching fronts on my T Type- and other than needing to make some 3/16" spacers to clear the LS1 calipers on the front i have had no issues with clearance and it it looks right.
Engine: 5.7 HSR
Do you have any pictures of your car? Any pictures of the clearance on the inside of the wheel? Are you using spacers on the rears?
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
No they did not - they had Buick specific 15" wheels. The GNX had 16" wheels from the TA (in black).
But it is an easy upgrade since the 15" wheels on the GN were sloppy handlers.
Car: 86 Camaro
the GNX had the same style of wheel as the GTA, but with different backspacing. they put the bigger wheels on that car because they were going to adapt the Corvette 12" disc brakes but that got shelved due to production costs. it would have been the only G body ever built to not have shitty brakes..
matts86cam
Exterior Parts Wanted
Sep 5, 2016 08:54 AM
1Aauto
Sponsored Vendors
Apr 12, 2016 01:48 PM
