Rear Disc Brake Pad Help
Old Mar 26, 2016 | 10:08 AM
88 vert guy's Avatar
Hello Everyone:
Question: Are the pads below correct for a 1988 IROC with RPO code J65?
Or are they for 1LE or Corvette?
Thanks!
Old Mar 26, 2016 | 11:29 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Rear Disc Brake Pad Help
I Believe Those Are For The Perf Pkg (1LE)
Old Mar 26, 2016 | 11:37 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Those are standard on the rear for 89-97 f-body. And corvette from ?? till 96
sad but I'm Not 100% sure when the 1LE F-body started to use them.
Old Mar 26, 2016 | 11:42 AM
If your car has the aluminum calipers, they are correct.
If yours are cast-iron, which is far more likely, then no, they are not the right ones.
Old Jul 14, 2017 | 08:32 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Those are NOT J65 pads.
J65 uses MKD154 front and rear I believe.
Old Jul 14, 2017 | 09:13 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
All 82-92 four-wheel disc brake cars, regardless of caliper type (iron or alum) are RPO J65.
JamesC
Kfly67
May 14, 2017 08:37 PM
88IROCvertZ
Jun 20, 2016 11:27 AM
88 vert guy
Apr 4, 2016 11:01 AM
86IROC112
Mar 26, 2016 04:38 PM
lugercollector
Mar 21, 2016 05:23 PM
