Question for those who fiberglassed their dash pad...
Old Mar 23, 2016 | 05:59 PM
86IROC112's Avatar
Car: 1986 IROC Z
I have read several threads where guys have used fiberglass to refurb their dash pads. In each one they have applied bondo body filler on top of the glass. Can't fiberglass be sanded smooth enough to paint? I used to use fiberglass on RC airplanes I built as a kid and thought I remembered sanding it smooth and painting it??
Old Mar 26, 2016 | 04:38 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Question for those who fiberglassed their dash pad...
I fiberglassed mine and you can read the thread here:
https://www.thirdgen.org/forums/inte...dashboard.html
You can sand down the fiberglass as long as you use enough fiberglass. What you would probably need to do to ensure you dont have any of the mat/weave hairs coming through is to lay the mat on and add your fiberglass and let it cure. Then just add more fiberglass resin only again on top. What I ended up doing at a member's suggestion was to make that fiberglass resin/body filler milk shake slurry stuff. Basically mix together your resin and add in some body filler to get your desired consistency. That worked well. Then I just used a skim coat of body filler and a bunch of spot filler.
NHL69
Exterior Parts for Sale
Apr 16, 2016 07:44 PM
1fastrock
Mar 27, 2016 09:57 AM
88_SportCoupe
Mar 25, 2016 08:24 PM
gnilson
Mar 24, 2016 07:03 AM
BOTTLEDZ28
Exterior Parts Wanted
Mar 23, 2016 09:09 PM
