87 9 bolt drivers side caliper question
Old May 28, 2017 | 11:05 AM
baker440ex's Avatar
Car: 87 Z28
Engine: Roller 305 LG4
Transmission: NWC T5
Axle/Gears: 9 Bolt 3.27 LSD
hey guys, forgive me if this topic is posted elsewhere...
ive got a 9 bolt out of an 87 trans am with the cast iron calipers going into an 87 camaro with the 10 bolt... on the drivers side i believe there is a hard line all the way to the caliper, which threads in to a banjo bolt block.
just mocking this thing up in hand, when i seat the banjo bolt into the block, with a washer on each end, and look through the brake line fitting hole, the hole in the banjo bolt is no where lined up with the fitting hole. it doesn't seem to me like the copper washers will crush down enough to where all the holes will line up. if i remove the washers then the hole is visible but still off a little bit. am i over thinking this? i checked the original banjo bolt as well and it is the same as the new one. attaching some pictures so hopefully the question will make more sense. one is with a washer and one is without. basically is this correct or do i have the wrong bolt for some reason?
Old May 28, 2017 | 11:06 AM
baker440ex's Avatar
Car: 87 Z28
Re: 87 9 bolt drivers side caliper question
here are the pics. first is with a washer and second is without
Attached Thumbnails 87 9 bolt drivers side caliper question-.jpg   87 9 bolt drivers side caliper question-without.jpg
Old May 28, 2017 | 07:05 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The holes do not need to line up, the bolt is necked down under the head and allows fluid to flow around it to the hole.
That new bolt looks way too short though, I would use the old ones
Old May 28, 2017 | 07:24 PM
baker440ex's Avatar
Car: 87 Z28
Thanx scooter, actually answered my own question shortly after posting this...Once I realized the "taper" in the bolt I went ahead and gave it a go...And yes I did use the longer bolt. Got fluid to the bleeder so everything is good. Thanks again though. Helps having a place to ask questions
Old Jul 17, 2017 | 05:53 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Where did you find those banjo bolt blocks? I cant find them anywhere online
Old Jul 19, 2017 | 06:11 PM
baker440ex's Avatar
Car: 87 Z28
I just cleaned up and reused my originals. But if you google "Banjo bolt block" a couple things come up
http://www.classicchevy.com/chevy-br...iABEgJm8_D_BwE
Old Jul 19, 2017 | 06:16 PM
TylerSteez's Avatar
Engine: 383 stroker
thanks for the reply, I saw that site but wasn't sure if it was the correct threading for our cars, I guess it's worth a shot to order and find out.
