Another drum > disk question...
Old Aug 18, 2016 | 06:12 PM
85TAsdro's Avatar
I know this has been covered countless times. However I can't seem to find an answer I feel comfortable operating off of.
Currently I have an 85' TA with the 9 bolt Borg Warner/ open with 3.08 gears, and drums.
Im going to look at a 9 bolt, posi with 3.27s and disks this weekend. So if I am to just swap out my rear with this one, I would only have to change my e-brake cable, and proportioning value correct? Ive heard a few different opinions on this.
First post, thanks fellas
Old Aug 18, 2016 | 08:38 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Another drum > disk question...
Don't forget about speedometer re-calibration.
Old Aug 19, 2016 | 06:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yep and yep.
JamesC
Old Aug 19, 2016 | 09:06 AM
85TAsdro's Avatar
How exactly is that done? I would just need to swap out the speedo gear from the side of the trans? Just take the gear from the parts car correct?
Old Aug 19, 2016 | 09:58 AM
85TAsdro's Avatar
Originally Posted by JamesC
Yep and yep.
JamesC
So the proportioning valve is located on the rear where it splits the lines? Or are we talking the valve right after the master cylinder? I should be able to swap over the parts from the other car correct? Or is there a good place to get them after market valve and cable?
Thanks fellas
Old Aug 19, 2016 | 10:46 AM
2012sergen11's Avatar
Car: 1987 Trans Am
Proportioning/Combination Valve is right under the master cylinder with 2 lines going in and 3 out I believe.
valicswarrior
Jun 21, 2016 08:25 AM
shugart111
Apr 11, 2016 09:37 AM
stephenscamaro
Mar 30, 2016 03:12 PM
p-balin432
Mar 25, 2016 10:49 AM
MikeDwhoROCZImports
Aftermarket Product Review
Apr 20, 2001 08:48 PM
