Ls1 master with stock brakes
Car: 1984 Camaro Z28
Engine: 305 LG4
Can i use the ls1 master with stock iron caliper fronts and rear drums. I plan on installing an adjustable proportioning valve and the c4 front conversion and keeping the rear drums
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Ls1 master with stock brakes
Sure, you can use the stock LS1 master cylinder. Like you said just run the correct proportioning valve or an adjustable valve.
