89 PBR Rear brakes - 9 Bolt
Car: 1986 Firebird TA
Engine: SBC 350
Transmission: TH350 Stage2
Axle/Gears: 9 Bolt rebuilt w/3.70
I am wondering if anyone has some pics of the 12" BBR rear brakes on any thirdgens with 9 Bolt? The 10 bolts are different since I have a set of them also I forgot to take pics before I stripped my 89 firebird so I can get them all back together correctly on 86 TA.
Also so you have to push back those goofy caliper pistons?
Howie
Howie
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 89 PBR Rear brakes - 9 Bolt
There is a tool to push the piston in if you don't have a large C clamp or channel locks to squeeze the piston in.
All the PBR brakes are the same whether you put them on a 9 or 10 bolt. The caliper trails the axle and the bleeders point up
