Drum to disc conversion
Old Nov 26, 2017 | 03:34 PM
challenger71's Avatar
Car: 71 Challenger, 70 duster, 89 iroc,
Engine: hemi and 440
Transmission: a-833 4 speed
i am swapping a drum brake out of a 91 firebird and replacing it with a disc setup from sn 87 camaro. My question is if thr emergency brake lines are the same or do i need the ones from the camaro?
Old Nov 27, 2017 | 02:46 AM
Drew's Avatar
Re: Drum to disc conversion
Don't do it. Not worth the trouble. Delco Moraine discs don't work as well as the drums.
Just off the top of my head, the cast iron rear calipers used a different master, prop valve, lines, and cables than the drums. Also the E-brake is self adjusting on the 91, and manual on the 87. Not sure what all problems you'll run into, but considering the cast iron caliper disc setup is garbage right from the factory, it's really not even worth considering.
Old Nov 27, 2017 | 07:03 AM
This is not my car. I am being paid to do this conversion. The customer gets what the customer wants and pays for.
Old Nov 27, 2017 | 07:39 AM
BOTTLEDZ28's Avatar
Transmission: A4
Ebrake lines need to be swapped out for ones from a disc rear. Preferably, an early 91 model year car with disc. You can find everything you need for this swap at www.flynbye.com.
I just swapped out the drums on my 91 for a disc setup with 13" rotors. I bought my cables from Ed from the above site and they worked perfect.
I will add that I used PBR calipers from a 1992 camaro and custom brackets from Ed as well. I was able to keep the original rearend and just do the conversion. No drilling or cutting other. It was a 100% bolt on swap.
As for the proportioning valve, I replaced the spring inside the original valve on the car. Took me 5 minutes to change. There is no need to swap out the entire valve. There is a huge thread on here about the spring upgrade. My car has 14" rotors up front and 13" rotors out back. It stops too good now.
Old Nov 27, 2017 | 10:33 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I believe the backing plates have a different bolt pattern
Old Nov 28, 2017 | 01:27 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Get the E-Brake cables from the Camaro. Drum cables and Disk cables are different.
Old Dec 10, 2017 | 07:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There's info on thirdgen braking systems (and conversions) in the following link that may be helpful.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Dec 10, 2017 | 10:46 AM
She is all converted. Was a simple swap. Had to change out the ebrake handle and cables for the adjustable cables on the 87. Bought all new calipers, rotors, and lines from rockauto. And new Founders trailing arms. Buying everything new is the way to go.
Old Mar 26, 2018 | 02:34 PM
dutch-z28's Avatar
Car: 1987 Camaro z28
Engine: 305 lg4
Transmission: th700r4
Axle/Gears: 273
Hello.
i have a 87 camaro z28 with stock drum brakes. I want to install a rear end with disc brakes , because i blew up the stock rear end . The rear end i have i believe is from a 86 with stock 10.5 inch rotors . Can anyone tell me which aftermarket proportioning valve Will fit without modifications .
B.t.w sorry for my bad english. I am from the netherlands
Old Mar 30, 2018 | 07:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
No aftermarket valve will.fit without modifying the lines. You need to use a factory valve from a similar year disc/disc car.
