HELP A NEWBIE OUT....plz
Old Apr 19, 2018 | 01:45 PM
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
I have a 92 z28 with disk brakes that we are restoring. I am in need of a new rear end but have nobody that can repair it anytime soon. I have the chance to get a rear end for 100 but it has drums. Can this work with the system till the stock one is rebuilt? Thank you for the help!!
Old Apr 19, 2018 | 02:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
Re: HELP A NEWBIE OUT....plz
The drum rear will bolt right on but the brake lines will not work. Neither will the Ebrake cable. Even if you managed to get the brake lines hooked up, the proportioning valve would most likely cause the drum to lock up under moderate to heavy load.
If you are restoring this car then it most likely isnt going to be road worthy in the next month or three so Id suggest looking around for someone to rebuild the original disc rear.
Speaking of which, what is wrong with it?
Fritzee
Feb 8, 2010 01:36 PM
idiot254
Mar 13, 2009 11:05 AM
388
Jun 18, 2006 08:23 AM
Usmuscl398
Oct 3, 2004 10:00 PM
maksik7
Apr 15, 2001 08:28 PM
