caliper swap
Old Apr 21, 2018 | 09:03 AM
m smith's Avatar
caliper swap
Will 1989 stock rear calipers be direct bolt on for 1988 stock rear calipers on a 9-bolt.
Old Apr 21, 2018 | 10:19 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: caliper swap
If you currently have the iron rear calipers, I believe 89 had the aluminum PBR calipers. If thats the case, they will physically bolt on to your rear, but you'll need the axle flange brackets and caliper brackets along with them. They are a completely different setup so you need everything with them to get them to bolt on.
Old Apr 21, 2018 | 11:12 AM
m smith's Avatar
Re: caliper swap
Thank you for your reply.I wasn`t sure if it was a direct swap or not. Thanks for the information.
JamesC
Mar 22, 2026 09:55 AM
scorp88
Aug 15, 2020 03:07 PM
gcj280
Apr 25, 2017 04:43 PM
anesthes
Oct 11, 2016 07:48 AM
blackbeauty
Brakes
Sep 29, 2016 05:50 PM
