LS rear brakes on 84 Camaro drum brake rearend
Old Aug 23, 2018 | 03:45 PM
84 zee's Avatar
Have backing plates,rotors and calipers all off of 2002 SS, So I will need aftermarket brackets to make this work where can I buy them at?
Old Aug 23, 2018 | 04:22 PM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Re: LS rear brakes on 84 Camaro drum brake rearend
No brackets needed, you will need to modify your existing drum flange and bolt them up. Here’s a tutorial.
https://www.thirdgen.org/ls1reardisc/
Old Aug 23, 2018 | 06:08 PM
84 zee's Avatar
Thanks for the help Much appericated
Old Oct 22, 2019 | 09:35 PM
wbrooks63's Avatar
Car: 1988 sport coupe convertible
Engine: 5.0 TBI. LO3
Transmission: Manual 5 speed
Will this work with C5 rotors and C5 calipers/brackets?
Old Oct 23, 2019 | 03:17 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
all rear brakes will be same as far as upgrading from drum only difference will be the bracket
4th gen brakes are direct swap over and anything else you need to but a bracket
bigbrakeupgrade.com is a good source for products and personally brought a couple kits
and quick shipping
turd_gen
Brakes
Mar 12, 2019 01:57 PM
Ninety-One
Brakes
Apr 10, 2016 11:25 PM
seanof30306
Aftermarket Vendor Review
Dec 14, 2014 11:12 PM
scuzz
Brakes
Aug 22, 2006 11:40 AM
Daz
Brakes
Mar 9, 2005 09:49 AM
