converting to rear PBR brakes
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I have a 9 bolt with rear disk brakes on the car and a 4th gen(LT1)rear complete with calipers and rotors.Is it possible just to take the caliper brackets off the 4th gen and slap em on the 9 bolt?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link may provide some info, including where you may find the 9-bolt backing plates:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
JamesC
Backing plates, lines (hard and flex), and parking brake cable. I've been told, but have no personal experience, that 9-bolts don't require shimming. However, you might keep that in mind if the carrier doesn't center over the rotor.
JamesC
JamesC
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes...all you'd need is the correct backing plates and "maybe" new axle hard lines. I'd try the LT1 lines first and try to make them fit, they aren't that much longer than the 3rd gen lines.
Daz, sent you a PM about NE3G...
Ed
Ed
I'd definitely keep the 9 bolt if you like the gear ratio you have, stronger than the 10 bolt.
Ed
Ed
Re: 9vs10
[QUOTE]Originally posted by doc76239
But 9 bolts are harder to find parts for. [/QUOT
If you don't break it, then you don't need parts. Only abuse will break your rear axle componets.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Re: 9vs10
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
What?????????
I have an 89 9bolt with pbr and 3.27's. I can't find a drivers side axle shaft to save my a$$. Unless I want to spend 150+ for a new one.
1992 Trans Am
May 10, 2023 07:19 PM
Eric-86sc
Apr 3, 2016 03:52 PM
