Why spend 2x as much for a proportioning valve?
Old Dec 16, 2018 | 06:32 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
I'm upgrading my brakes at all 4 corners and expect that I will need an adjustable proportioning valve. There are several threads here and in other forums using the Wilwood 260-11179, which sells for about $90 and is a 2 inlet, 3 outlet valve with a stop lamp pressure switch. Wilwood also has a single inlet, single outlet valve 260-10922 for about $42. Why would I need the more expensive valve? It seems like they both have the same functional/pressure specs. Obviously I'll need to tee the front lines together, but I don't think that's worth twice the cost of the single inlet/outlet valve. What am I missing? Why are more people talking/posting about the 260-11179 when it seems the 260-10922 is more cost effective and does the same thing?
Old Dec 16, 2018 | 06:36 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Why spend 2x as much for a proportioning valve?
There is no advantage to the 5-port model. The stop lamp switch is unusable with your stock warning light. Just avoids using a Tee if that is against your religion.
Old Dec 17, 2018 | 05:12 PM
Lurbie's Avatar
Car: 89 Camaro
Thanks QwkTrip, that's what I was hoping to hear.
Old Dec 18, 2018 | 10:44 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I was wondering this exact same thing myself as it i one of the projects to do on the car this winter.
Good to hear clarification about it.
I was deciding between these two, but its good to learn that the 5 port one wont work and that I should just go with the one in- one out version.
My rear 12"PBR conversion brakes from flynbye are great but even thought I installed a disc/disc proportioning valve years ago, my rear brakes never felt like they were doing the "proper" amount of work. I was reading on TGO about buying a different spring and replacing it in the PropValve, but I also was curious about adjustable PropValves.
I think my plan is this (and correct me if I am making a mistake or not thinking this out correctly).
I need more rear brake input. I will get the Wilwood 260-10922. I will then find a place along the length of the brake line going t the rear axle and cut the brake line. I'll then need to flare it accordingly ( to be an inverted 3/8" flare with 24 nuts? ) after putting the fittings onto the line. Then I will take the rubber cap and nut off of the front part of the PropValve, remove the spring assembly completely, and put the nut/cap back on. Add fluid and bleed the whole brake system. I will then go for a short ride around the neighborhood making adjustments to the PropValve via turning the **** until I get the rear brakes feeling more grabby.
sound about right? anything else I need to consider?
ringo234
Jan 4, 2007 06:24 PM
ringo234
Southern California Area
Dec 31, 2006 08:54 AM
hpjspdr4l
Dec 11, 2003 12:32 AM
Kingtal0n
Nov 15, 2002 06:26 PM
BOTTLEDZ28
Apr 16, 2002 11:24 AM
