LS1 fronts - BOTH seized. ???
Old Apr 15, 2019 | 03:01 PM
Abubaca's Avatar
So I've had my LS1 front brake set up for close to 10 years now, but I don't put many miles on the car. Maybe 1000 a year? If that? Anyhow, BOTH calipers are having trouble releasing. I can turn the wheel, but they're definitely tight. I know this happens from time to time, but what are the chances of them BOTH happening at the same time, or at least CLOSE to the same time? I've changed rear brakes recently, but did NOT bleed the entire system, Just got the rears working. Brakes have been working fine, but again, it's not like I drive a lot.
What could cause this? Thoughts? ....any concern, or would you just fix 'em and not worry about it?
Old Apr 17, 2019 | 11:53 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LS1 fronts - BOTH seized. ???
Had both front calipers on my ram go at the same time while driving home. So it can happen.
As for a cause, old fluid and excessive moisture in the system?
Old Apr 17, 2019 | 01:46 PM
Abubaca's Avatar
Yeah.....I spoke with a buddy of mine who is a professional mechanic. He said any fluid over a few years, on a NON daily driven vehicle is asking for trouble. Said they may never have a problem, but he said time, and lack of movement was a killer.
....so new fluid it is. -and calipers.
Old Apr 17, 2019 | 04:19 PM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Also check the caliper guide pins, sometimes they get dry and hang up.
Old Apr 18, 2019 | 07:20 AM
Abubaca's Avatar
Agreed. I will go through them both and see what's going on. I'll be prepared for new calipers, but hopefully $15 dollars worth of rebuild kits will be all it takes. We'll see.
Old Apr 18, 2019 | 07:42 PM
Drew's Avatar
All of my recent brake caliper lock-up issues went away the second I disconnected the hoses. The pistons weren't seized, it was just the tiny pin hole in the steel ends of the rubber hoses that had corroded or been plugged by debris in the fluid. It's worth a try before tearing apart the calipers.
Old Apr 18, 2019 | 10:09 PM
Abubaca's Avatar
I'll look into that as well.
camarosource
Feb 14, 2012 07:53 PM
T/Atime
Wheels and Tires
29
Nov 13, 2011 11:23 PM
Craig84Z
Brakes
Mar 5, 2006 07:10 AM
gmgod
Brakes
Nov 26, 2005 01:11 PM
