Brake Line Routing
Old Nov 19, 2019 | 12:58 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Brake Line Routing
Anyone have a diagram or a pic of fuel/brake line routing and proper locations of mounts for my 85 Camaro. Comp ate some of my pics.
Old Nov 19, 2019 | 08:04 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Brake Line Routing
Maybe the attachments will help. Keep in mind that there could have been some deviation between the drawings and actual production.
Old Nov 19, 2019 | 09:24 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks.
Old Nov 20, 2019 | 12:16 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
What are you going to do about exhaust ? If you are going to route it like the factory did you brake line might be an issue. I used the stainless works swap headers and they left 1 inch of room in between the header and the frame rail right where all the lines were, I did not like that. True duals required me to move all of the plumbing. I moved it higher up into the trans tunnel and the just forward of the shifter I routed them up towards the center of the tunnel to keep them away from the headers and heat. Just something to consider.
Old Nov 20, 2019 | 01:07 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
I’ll keep that in mind.
Old Nov 30, 2019 | 08:39 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Those PDF's look a lot like the original factory line routines on my '82.
The lines from below the tank to up to the firewall are are still original on my car. Everything else I moved around for better clearance.
I've never understood why the factory front brake lines went under the "frame rail" (right next to the exhaust) when there are conveniently placed holes in the fenders that look like they were made for brake line routing. You can probably guess were i put mine.
remltr
Sep 26, 2009 07:05 PM
MartinC
Brakes
Apr 11, 2006 07:35 AM
83 Crossfire TA
Oct 16, 2002 05:52 AM
