Dougs LT's and front brake lines
Old Sep 22, 2009 | 04:29 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Just put a set of Dougs LT's on my 91 Z. The passenger side brake hard line is really close(just about touching) to the header. This line runs along the k-member. What have you guys done with this line?
Old Sep 22, 2009 | 04:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Dougs LT's and front brake lines
bend it out of the way?
Old Sep 22, 2009 | 05:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Somehow you want to safely relocate it as was stated above. You don't want your brake fluid boiling. This is one of the reasons for using a good quality set of shorty headers. You don't have these types of problems for the small gains of horsepower with the long tube headers.
Old Sep 23, 2009 | 03:15 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Unless it's actually touching, I woudlnt worry too much about it.
If possible I would run it for a while and try to feel how hot the brake line is to the touch near the header, just dont burn yourself.
I know with my LT's the collector is very close to my brake and fuel lines but I never have any trouble with them. Air is a poor conductor of heat.
Old Sep 23, 2009 | 04:15 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Shorty vs. long tube has nothing to do with how they route at the primaries. I am not sure why you would think that?
My Doug's come pretty close to the brake lines but do not touch them. I am planning a swap to Ford brake fluid since it supposedly has the highest rated boiling point of all the readily available over-the-counter brake fluids available. This should take care of any problems that would come with having the lines that close to the header though.
Old Sep 24, 2009 | 11:57 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
My Edelbrock shorties were nearly touching my brake lines. I just bent them out of the way.
Old Sep 26, 2009 | 07:05 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
You could always pick up a long piece of brake line and do a custom bend if bending the original piece doesn't give you enough clearance.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
