9 bolt brake part numbers
Old Nov 27, 2019 | 07:12 PM
patriot_tech's Avatar
I am putting a 9 bolt 3.27 PBR caliper rear end in my car. I want to replace the rotors, pads, and brake hoses at install. I just spent the last 1.5 hours searching, but can't seem to find the info I need. The only thing I found was MAYBE the rotors are 55022.
Anyone have the correct part numbers for those items so I know what to buy?
Thanks in advance for the help!
Old Nov 27, 2019 | 07:15 PM
Drew's Avatar
Re: 9 bolt brake part numbers
Look em up on Rock Auto. Use the discount code from here - https://www.thirdgen.org/forums/afte...t-codes-3.html
Old Nov 27, 2019 | 07:21 PM
I am under the assumption that these are the 1LE rear brakes. Everything on rockauto excludes the 1LE package.
Old Nov 27, 2019 | 07:44 PM
Drew's Avatar
It doesn't matter. All 89-92 rear disc cars got the same brakes regardless of 1LE. 1LE applies to the front brakes only.
Old Nov 28, 2019 | 06:46 AM
Oh ok. Thanks Drew!
camaro211z28
Brakes
Jun 17, 2014 06:33 AM
bigals87z28
Brakes
Apr 27, 2008 04:27 PM
IROCJoyce
Brakes
Dec 10, 2007 12:30 AM
ineeedmorespeed
Brakes
Sep 19, 2007 06:13 AM
pvt num 11
Brakes
Jan 21, 2005 11:43 PM
