Brake line adapter for Wildwood Master cylinder???
Old Jun 10, 2020 | 07:29 PM
Ct1987's Avatar
Hi, I looked for the answer to this question but could not find any. I am thinking of converting the master cylinder on my 1987 formula to a Wildwood cylinder. The brake line fittings on the 3rd gen are unique and are not compatible with most if not all aftermarket master cylinders. I really don't to go through the trouble of flaring new lines. Has anyone found an adapter to convert the 3rd gen fitting to one more common.
Thanks,
Louis
Old Jun 10, 2020 | 09:47 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Brake line adapter for Wildwood Master cylinder???
Don’t have an exact solution for you but can provide some related information that may be helpful.
If you buy the Wilwood kit that comes with a proportioning valve you can get adapters to connect the brake lines to the proportioning valve. You can see what I did at the post link below. I have fitting part numbers in this post as well:
https://www.thirdgen.org/forums/memb...ml#post6251474
Old Jun 11, 2020 | 09:21 AM
Ct1987's Avatar
Hi Battperson....
This is just what I was looking for. Thank you for taking the time to reply. One last question, what is the part number of the master cylinder?
Also, if you did not know, they now make a RH bracket and lines. Wildwood part Prod #: 260-15048
Louis
Old Jun 11, 2020 | 12:27 PM
battmann's Avatar
The part number for the master and proportioning valve I bought is 261-13269-BK.
Originally Posted by Ct1987
...they now make a RH bracket and lines. Wildwood part Prod #: 260-15048
Just my luck. I did not know that and just started having a guy fabricate me a bracket last week. I can't win.
Old Jun 11, 2020 | 02:07 PM
Ct1987's Avatar
Thanks again. I know how you feel. No matter how you try, that cards are against you. Wash and wax your car and before you can get it back in the garage, it pours. Drop a wrench whilst working on the engine. It falls under the car mathematically exactly in the center, where you cant reach it. Paint a piece of trim that you have painstakingly prepared and as soon as you turn your back, a large bug falls on it and does the swan dance.
This is all called Murphy's law. Hate that guy. BTW, I just noticed your blueprints. As a thank you to you, I just ordered one for a 86 firebird, close enough to my 87.
Louis
Old Jun 13, 2020 | 02:08 PM
battmann's Avatar
Thanks Louis!
i make these blueprints as people request them. I’ve been pretty busy with Father’s Day coming up.
Once I have more free time I’ll make a 1987 Firebird one for you.
Old Jun 13, 2020 | 07:47 PM
Ct1987's Avatar
Thanks, would appreciate it. The quality of your work is outstanding.
Louis
sheltonw3
Brakes
Sep 20, 2012 11:28 PM
IEatRice4dinner
Brakes
May 16, 2009 05:30 PM
jay_d
Brakes
Oct 17, 2007 10:40 PM
EVOla_VIRUS
Brakes
Jul 10, 2007 12:18 PM
91GTABird
Brakes
Jan 7, 2006 11:11 AM
