Steering wheel shakes when braking
Old Oct 15, 2020 | 03:29 PM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I have a race car only, so after going through the traps at about 118, I get on the brakes fairly hard to get the car to slow down. The car starts slowing down, and the steering wheel shakes bad under braking. I have a s10 manual steering box, with a grand cherokee steering shaft. All of the other steering items are stock. I am not sure if I need to replace the brakes, or the center link and the rest of the steering related items. Any thoughts?
Old Oct 15, 2020 | 04:01 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Steering wheel shakes when braking
My thoughts ;
After you do the "wiggle test" to see if there is any play in your front end components , there will either be excessive play in one or more components , or there won't .
If there is play , replace the worn part(s) . If there aren't any parts with excessive play , it's highly likely that one or both of your front rotors are warped ......
Old Oct 17, 2020 | 09:29 AM
Could be something about the steering or suspension; also highly likely that it's a warped or otherwise damaged rotor. If it was mine I'd start with the rotors, they're cheeeeeeeep anyway, and almost always messed up it seems.
Old Oct 17, 2020 | 09:49 AM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
My thoughts ;
I was thinking that one of the rotors were warped, but I guess I have never had one that bad that it would shake the whole steering wheel. I have only felt it through the pedal. However, my racing season is done for this year, so I know I will do new rotors and probably just rebuild the steering too. Thanks guys
Marc Webber
May 6, 2017 08:11 AM
SomeGuy25thZ
Jun 4, 2013 01:48 PM
IROCMAN89
Southern California Area
19
Feb 27, 2010 01:41 PM
BC GTA
Mar 6, 2009 06:06 PM
Dragons91RS
Dec 25, 2003 01:14 AM
