Are 10 bolt rear and 9 bolt rear rotors interchangeable?
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I'm wondering if the brake rotors are the same between a 10 bolt rear end and a 9 bolt rear end? Obviously the calipers are different, but how about the rotors? I'm overhauling a 1989 IROC, and I have a 1986 IROC parts car that has all new brake components. I'm just curious if I can at least get by using the rotors I already have on the parts car?
Thank you in advance!!!
Re: Are 10 bolt rear and 9 bolt rear rotors interchangeable?
If the calipers are different, then the rotors are too. (12" vs 10½")
If the calipers are the same, either both cast-iron or both aluminum, then the rotors would also be the same.
Thank you!!
