REar Rotors
Old Aug 23, 2004 | 01:44 AM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
REar Rotors
I need rear rotors for a 9bolt...Cross Drilled, and ball milled slotted, zinc plated and pads to fit....where canI find these at a reasonable price??? Thanks, Cocacolakid
Old Aug 23, 2004 | 05:16 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
Oh boy
A 9 bolt rear end is hard to find parts for. I have one that needed a drivers side axle shaft. I couldn't get one for less than the price of a 10 bolt. So I swapped in a 10 bolt. The parts just aren't there.
Old Aug 23, 2004 | 09:04 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What year car?
Ed
Old Aug 23, 2004 | 11:56 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Once again, 9 bolts used the same rotors as 10 bolts of the same year. There is nothing special about the brakes on a 9 bolt.
Old Aug 23, 2004 | 03:13 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
That was my understanding..
Old Aug 23, 2004 | 04:04 PM
Car: 84Z & Porsche
Rebuilding the calipers
Are the caliper kitson the 9bolt the same as on the 10 bolt ...So if I get a rebuild kit for a 10 bolt will it rebuild a 9bolt??? Thanks, Cocacolakidd
Old Aug 23, 2004 | 04:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You won't get a kit for a 9 bolt or a 10 bolt. You'll get a brake kit for the year of your car and it will work.
Old Aug 23, 2004 | 08:14 PM
Car: 84Z & Porsche
9bolt repair
I need to rebuild the calipers for my 9bolt...so if I get a repair kit for a 1988 rear caliper repair kit, it will work???. thanks, Cocacolakidd.
Old Aug 23, 2004 | 08:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, the fact that your calipers happen to be bolted to a 9 bolt is irrelevant.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
