Front right rotor hotter. Slight pull to right when braking
Car: 1987 Trans Am
Engine: 5.7
First post here guys. Been lurking for a while now.
I just replaced all brake components besides the booster and the hard lines. Used power stop complete kits front and rear. I’m getting a slight pull to the right when braking and that rotor reads hotter than the others. I installed an adjustable prop valve and did all the flaring myself. Brakes work good other than the issues I mentioned above. Think it’s possible there is a construction in the front left line causing the front right to work harder? Trying to get this sorted before I adjust the front and rear pressure so most of the load is on the front at the moment. Thanks for any insight or help as I am new to third gens.
Re: Front right rotor hotter. Slight pull to right when braking
Hi KnightG, welcome to TGO
I don't think your problem is on the left, my best guess is the caliper on the right is a bit tight or binds a bit and that is causing the increased temp (and grabbiness)
PS, please don't hate me for saying this, it's my own personal experience only, but, , , I have been burned once on "Powerstop" parts and now have no faith in the brand.
Car: 1989 IROC-Z
Engine: L98 350 TPI
Seems like there's something wrong with the caliper. Aside from bleeding it again, I suppose you could pop it off and inspect the piston for signs of friction, actuate it in and out a bit to see if you can free up whatever's happening there.
It could also be a faulty part, I believe Powerstop sells remanufactured calipers so it's possible that one was just too far gone.
Car: 88 Camaro
Engine: L98 350
Did you replace the flex hoses in the front? Those are noted for getting constricted at the center mounting collar and holding pressure in the line.
Car: 1987 Trans Am
Engine: 5.7
Thanks guys. I didnt expect powerstop to be without flaws, the price was right for what I was doing. I remember having trouble getting the clips and pads installed on one of them. It was really tight.
I replaced all the flex hoses with braided so that’s not the issue.
I will take the caliper off and add some lube and check the piston. It seemed to be a little better today so maybe it just had to self adjust?
Car: 1987 Trans Am
Engine: 5.7
Here is a pic of the car. Put a 4th gen ls rear end and c5 wheels on it. Regret doing the wheels as I have quite a bit into it with spacers and tires. Can’t beat the price on the rear end though. Huge difference.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Good-looking car, and I like the wheels...
