Master cylinder question
Old Dec 2, 2021 | 08:12 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Picked up a 85 sports coupe in bad shape. Noticed that the rear reservoir was empty. Completely changed all brakes and flex line's. Had leaking in the line going to the back brakes in more than one place, so I replaced that line from master back. Bled the system and moved the car. Brakes not up and light is on. Do I have to bench bleed the master. Also the drum brakes in the rear I didn't adjust up. Do I need to do a little on them or they self adjust
Old Dec 3, 2021 | 02:12 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Master cylinder question
light on would make me guess the master has air in it. I'd bench bleed it on the car. And yes, adjust the rears up.
Old Dec 4, 2021 | 07:37 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Thanks for the confirmation
427F-Bird
Brakes
May 28, 2008 07:43 PM
Benny
Jan 29, 2003 12:15 AM
85IrocNOH
Nov 10, 2002 07:08 PM
