Parking Brake Light On. Possibly Bad Brake Booster?
Old Jan 11, 2022 | 07:12 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
So my 1986 Camaro IROC Z with all wheel disc brakes started having a weird issues over a month ago. Sometimes when braking or during slow turns, my engine bogs down and sometimes stalls. I replaced every vacuum line and will do the vacuum canister (I'm 99% that only controls HVAC inside). I'm wondering if it's the brake booster. My brakes themselves were fully redone 2 years ago (discs, calipers, pads, fluid, etc). But I'm 99% the booster is original, it has 225K+ miles on it. Could this be the early symptoms of a failing brake booster. Is there a way to test it to make sure?
I do know the parking brake light comes on when the battery or alternator has issues (alternator was replaced 3 years ago) but usually fuses pop and my headlight alarm stays on when that happens. I checked them both with the multimeter and no problems.
Old Jan 11, 2022 | 07:26 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Parking Brake Light On. Possibly Bad Brake Booster?
Has nothing to do with the brake booster. Either the parking brake switch is bad, or you have a leak inthe hydraulic system (or bad master cylinder)...
Old Jan 11, 2022 | 07:45 PM
Engine: LB9 305 TPI
Ok. Is there a way to check? The fluid in the reservoir is full.
Could a hydraulic leak or bad master cylinder also cause stalling? I haven't noticed any brake issues, pedal feels normal.
Old Jan 11, 2022 | 08:11 PM
T.L.'s Avatar
The brakes have nothing to do with stalling. Make sure the parking brake lever is completely in the down position. If the light stays on, I would suspect the switch...
Old Jan 11, 2022 | 08:36 PM
Engine: LB9 305 TPI
Yeah it's 100% down. I'll order a new switch and try that first.
blk95ta
Brakes
Nov 16, 2013 07:49 PM
RS Reaper
Jul 20, 2012 06:22 AM
Jun 9, 2007 12:45 AM
Rosadoc-Z
Brakes
Aug 9, 2006 03:08 PM
9225th
Sep 4, 2002 05:42 PM
