Rear disc brake for 88 Camero 2.8L
Someone stuffed a big motor in and the rear drum brakes look silly. I see conversion kits for $400 being sold with noname calipers, pads and rotors with the brackets hoses and lines and e-brake cables. Does anyone sell just mounting brackets alone? I can find the calipers, rotors and pads on my own.
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Rear disc brake for 88 Camero 2.8L
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
I did the LS brake swap. I bought the rear backing plate w/e brake bracket on ebay for $300 in excellent condition. For the LS swap you need the backing plate/e brake bracket if you want e brakes. If you go with LT brakes you need a bracket. I've seen pics but no template, dimensions.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I think the LT are the same as the later 3rd gen discs? If so, you can just grab the L bracket and drill a hole like for the LS brakes and itll hold the cables no prob.
Slowly doing my LS brakes still myself
tonys91rs
Feb 17, 2014 04:33 AM
Tibo
Nov 9, 2012 06:57 PM
