Wilwood FLSI and soft pedal.
Old May 16, 2023 | 08:36 AM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
I am beating my head against a wall on this one.
Ever since I installed Wilwood FSLI calipers on the front of my car my pedal has been inconsistent like there's air trapped in the system somewhere. I have bled every bleeder on them and am getting solid fluid with no bubbles. I have replaced the master cylinder and bench bled it. Every rubber line on the car has been replaced. There are no leaks anywhere. I attempted to use a Motive power bleeder on it but can't get the thing to seal up.
Last night I jacked the back end up as high as I could get it, and I tried to bleed it out again. Again, just getting solid fluid.
I even tried to crack the lines at the master cylinder and re-bleed the master.
Took it out for a drive and had a pedal although not the best. After a couple stops, it was going almost to the floor again.
Guys I'm stumped. Air trapped in the proportioning valve maybe?
Old May 16, 2023 | 08:46 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Wilwood FLSI and soft pedal.
Do you have the brake lines fitted to the top side of the caliper? Being placed too low on caliper would keep air trapped inside.
Old May 16, 2023 | 09:39 AM
Anti-Venom's Avatar
Axle/Gears: BW 3.23
Old May 16, 2023 | 10:19 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What booster and master cylinder are you running? Are you alternating the bleed on the front? Fixed calipers with two bleeders are a pain to bleed.
Old May 16, 2023 | 11:10 AM
Anti-Venom's Avatar
Axle/Gears: BW 3.23
Lines are ran to the "middle." (edit)
I'm running the stock booster and master. I've alternated from the inner to the outer bleeders and have bled both driver and passenger several times. I'm getting no air out at all.
Old May 16, 2023 | 05:23 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Not easy to see based on the angle of that one picture and the distance from the caliper, but is that a bleeder at the bottom of the caliper or a crossover tube? It kind of looks like all bleeders.
It also looks like the brake line is connected to the top of the rear of the caliper. I'd think there should be a hole in the center of the rear of the caliper for the brake line connection.
Old May 17, 2023 | 07:29 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I didn't see this at first but LA is correct. You should have a cross over tube on the bottom side of each caliper.
Old May 17, 2023 | 07:42 AM
Anti-Venom's Avatar
Axle/Gears: BW 3.23
These are the newer FSLI calipers with the internal crossovers, and the brake line enters the caliper in the center. They're designed where they can be mounted in either a leading or a trailing position. The older style Wilwood's had the external crossover tube and had to be mounted in a certain orientation.
I went out and attempted the pressure bleeder again last night. This time with c-clamps on the plate. The end result was once again another quart of brake fluid down my strut tower and all over my garage floor. I've used them with screw on caps and they work great, but for this type of master cylinder, the pressure bleeder was a complete waste of money.
Old May 17, 2023 | 08:21 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I have wilwoods front and rear. Fronts are 6 piston and rears are 4 pistons so they're not the exact same calipers but like yours, 4 bleeders, line in the center and no crossover tubes. I put a wilwood prop valve in and a new master (stock replacement) and all new lines. Initially I filled the system used a vacuum bleeder and started pulling the fluid. It took a lot! Getting a seal on the bleeder screws with the vacuum pump was a pain. There was tons of air. Initially driving the car I had to pump up the brakes to get pressure. I went back and bleed them more w the vacuum bleeder and then went old school and had my wife push the brake pedal and I finished bleeding them that way. I used a rubber hammer to tap the calipers to help move any trapped air. Probably went through 3 quarts of brake fluid w only a little spillage. I'd check your prop valve or replace it w a wilwood one. It doesn't have the safety valve to mess things up. When in doubt, bleed more!
Old May 17, 2023 | 02:22 PM
Abubaca's Avatar
Amen brother. Giant pain.
evilstuie
Brakes
May 25, 2022 09:26 AM
'91CamaroRS
Brakes
Jan 9, 2016 09:27 PM
crazynights
Sep 15, 2003 11:01 PM
Justin Moore
Jun 18, 2002 02:41 PM
