Need help with brake lines
Old Jun 20, 2023 | 10:13 AM
Ethan Lesz's Avatar
Car: 1989 Firebird Formula
Engine: LS2
Axle/Gears: 8.8 Rear end from hawks
I was wondering if anyone had any picture of how they ran there brake lines. I am new to this and have a 89 Formula with a LS2 and Hawks 8.8 Rear end. I just need some ideas on how I should run mine
Old Jun 22, 2023 | 10:55 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Need help with brake lines
Is the factory routing not an option?
Old Jun 26, 2023 | 11:41 AM
The factory ran them across the top of the axle tubes. T fitting at/near the center top of the pumpkin, lines down the sides of the pumpkin and along the top to the bracket for the rubber line going to the caliper. There were little strips of metal welded to the tubes that bent over on the lines to retain them. Stainless tie wraps would probably work fine for that.
You can get sticks of line at the parts store and make up whatever you need.
Old Jun 26, 2023 | 12:18 PM
91banditt2's Avatar
Engine: 5.7 HSR
The search function here an invaluable resource
Hawks 8.8 - LT1 Rear disks - Third Generation F-Body Message Boards
Old Jul 12, 2023 | 12:39 PM
Ethan Lesz's Avatar
Engine: LS2
I was more looking for where the brake lines go on the tunnel... I could not find them
Old Jul 12, 2023 | 02:10 PM
91banditt2's Avatar
Engine: 5.7 HSR
The metal brake lines that run from front to rear?
Old Jan 26, 2024 | 03:51 PM
Ethan Lesz's Avatar
Engine: LS2
Yes, I am having some trouble with the center brake line going up to the master cyl. It keep interfering with the steering shaft. Just looking to see if anyone has any pictures of how the have theirs set up
Youngs92
Brakes
Apr 24, 2013 06:22 PM
AZZ28
Jan 25, 2008 03:34 AM
KZad
Mar 22, 2007 07:37 PM
Pepsicola
May 4, 2003 04:26 PM
