K-member swap-Brake Lines
Car: 1990 IROC
Engine: l98
So it looks like I will have to open up the brake lines to swap out my k-member. Are there any tips to make this less "painfull" or can it be avoided somehow? Thanks for any help
P.S.
Any other tips for swaping out the k-member would be greatly appreciated.
Travis
P.S.
Travis
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: K-member swap-Brake Lines
open up the tangs, you might get to reuse them, if not go buy some brake lines and bend them up with your hands. parts stores sell them.
Car: 88 Firebird - SOLD!
Engine: 2.8L
Swapped out the K-member on my '88 & brake lines stay intact. Just remove the brackets that bolt the brake lines to the K-Member & carefully drop the member. No need to remove the brake lines & open up the hydraulic system.
Corky
Corky
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i never touched mine.
bent them a lil after the installation and they are hidden behind the k member.
WARNING.... make sure you get all the brake line brackets before dropping the k member.
when you think youve got them all, there is always one more.
Car: 1990 IROC
Engine: l98
Thanks for the replies. I took a good look at the K-member and attached brake lines in a wrecking yard. The car had to motor out so I think I got a good view of all the brackets. Thanks again.
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
When I installed my spohn k member I had to re bend some of the lines on the driver side. I think it was where the tabs mounted to the k member. I did it all by hand and have had no problem.
