AC Delco Part Number for Left Rear Flexable Disk Brake Line
Old Jun 7, 2024 | 10:41 AM
scorpiusx's Avatar
Car: 1985 IROC Z
Engine: 305TPI (LB9)
Transmission: TCI 700R4
Can anyone tell me what the AC Delco Part Number is for the Left Rear Disk Brake Flexable Line for an '85 IROC Z ??? (305TPI) THX...Joe...
Old Jun 7, 2024 | 11:03 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: AC Delco Part Number for Left Rear Flexable Disk Brake Line
19173455 should work.
Old Jun 7, 2024 | 11:15 AM
scorpiusx's Avatar
Car: 1985 IROC Z
Ok Thanks...Why does it say, "Exc Vehicles Built For United States Market"???...
Old Jun 7, 2024 | 11:39 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Couldn't tell you. It is a simple hose, id get a dorman replacement and be done with it.
Old Jun 7, 2024 | 01:05 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Before you buy anything, I'd suggest you look at what's on your car now, because the factory rear disc brakes with iron calipers, like your 85 and my 87, don't use a rubber hose on the left rear.
It uses only a hard line that runs all the way from the Tee to the caliper, and it's coiled (hence the description "flexible line") where it connects to the caliper. There's no rubber hose like the passenger side uses.
If you're upgrading to newer style rear brakes, then you'd need a hardline for 89 and the suggested rubber hose. But if not doing such an upgrade, then chances are the existing coiled hard line doesn't need to be replaced.
Iroc'nthe87
Exterior Parts for Sale
Jun 12, 2022 06:47 AM
Nervous2
Jan 19, 2015 03:23 PM
corvetteguy
Brakes
Aug 7, 2012 09:03 PM
Nervous2
Dec 21, 2011 10:29 PM
