ABS on a thirdgen (2024 edition)
Old Nov 7, 2024 | 07:39 AM
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Poked around here and there are some older threads (2015 and older) of people asking if it could be done but it appears nobody has done it. Sooooo, has anybody actually done it?
I figure standalone ABS using an MK60 (OEM on E46 BMWs), fourthgen rear and for the front ????.
Somebody doing it on a boxy Volvo:
Modern ABS for a tracked 240 (Teves MK60 swap) | Turbobricks - The Volvo Performance Community
Pat
Old Nov 7, 2024 | 08:30 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: ABS on a thirdgen (2024 edition)
A member on the forum here @McLovin1181 has installed this ABS unit on his Camaro.
Old Nov 7, 2024 | 04:49 PM
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
https://www.youtube.com/watch?v=x2xxe0Hv5z4
Well there's the "easy" button.
If he sees this, looks like you still have the stock rear? If so, curious if you considered a 98-02 fourthgen rear and (I assume) less machining/fabricating work. I have 2" bolt-on spacers with CCWs from a fourthgen and C5 Z06 Speedline replicas, so getting new wheels wouldn't be an issue for me.
Pat
Old Nov 11, 2024 | 11:04 PM
McLovin1181's Avatar
My video pretty much covers everything.
It's not an easy swap, but worth it for real race 3rd gen. Will end up costing $3,000-4,000 depending on what unit you pick.
I sold a M3 CSL 817 unit last week for $2,150.
Mk60 is pretty nice to have overall though.
I use it as a way to pull me back from overcooking parts of a race track.
A lock up could end up as a nice trip into the dirt and grass, but the ABS makes a big mistake a minor one.
At worst the car will go wide but I'll still avoid the dirt.
Also.
I accidentally damaged some of my PTFE lines with heat, So I ended up remaking them from stainless Hardline and AN flairs.
Oh boy is stainless hardline annoying.
Even with a tube straightener, $300 hydraulic flare tool, and a diamond flair hone tool.
Thirdgen Ranch
Mid-West Region
Apr 6, 2011 09:56 AM
LFN AT U
Apr 1, 2006 08:22 PM
1992rs/ss
May 6, 2004 11:52 AM
Blackened
Jul 12, 2002 03:24 PM
