4th gen master cylinder with 3rd gen brake booster
Old Nov 19, 2024 | 03:18 PM
H4lucinati0ns's Avatar
So I just swapped to rear disk brakes on my third gen. I installed a 4th gen master cylinder and a new adjustable proportioning valve. I made sure there were no leaks and bled the brakes all the way. When the car is on and there is vacuum running the pedal is very soft and makes a hissing sound but the car seems to stop ok. Is this a result of the booster going bad or do I need a 4th gen booster since it's a 4th gen master cylinder.
Old Nov 19, 2024 | 04:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 4th gen master cylinder with 3rd gen brake booster
Sounds like a bad booster.
Old Nov 19, 2024 | 05:16 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Rumor has it, you need a 4th booster w a 4th gen master. And I agree, hissing sounds like a booster
Old Nov 20, 2024 | 02:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
I've used 3rd gen boosters with 4th gen masters on a few cars, works fine, no issues. The problems can arise when using 4th gen pedals in a 3rd gen when using a t5 or other swap transmission that isn't a t56, the pin on the clutch pedal is in a different place and creates problems as there is not enough throw
theraymondguy
Brakes
Aug 26, 2024 10:44 PM
aussiesteve
Brakes
Sep 12, 2023 05:44 AM
Charged350
Brakes
Feb 11, 2009 02:02 AM
BOTTLEDZ28
Brakes
Apr 14, 2006 11:28 PM
Artem
Jan 30, 2004 10:45 AM
