will a 4th gen master AND booster swap right into our cars
Old Feb 5, 2006 | 11:06 AM
BOTTLEDZ28's Avatar
Transmission: A4
My 175K miles brake system is in need of updates and I was considering the 4th gen setup but need to know if the booster wil work or not. I know there are guys running the master and would like some feedback as far as what "mod" work needs tobe done if any to get this to work. I am about to swap in some Z06 front brakes and I have already swapped out my drum rear in favor of a 4th gen (LT1) disc rear. My next concern is the prop. valve.
Old Feb 6, 2006 | 12:42 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I would be interested as well, as I just put 94 rear disks on my 89 and I'm still having troubles with the fronts locking up before the rears. What are the advantages to going with the 4th gen master???
Old Feb 6, 2006 | 07:49 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
I will say I don't know if the booster will fit, but the bolt pattern is the same between the two and the pedal hookup is the same between the two, so stands to reason it should fit right in.
Kevin D.
Old Feb 7, 2006 | 07:34 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
It worked for me ('02 booster/master cylinder), but I can't remember if there were any modifications needed (maybe a little grinding on the firewall), and I won't be around the car for another few months to look and see.
Also, I don't know what the advantages of a 4th gen booster/master cylinder are; I just did it because I wanted to see if it would work.
Old Mar 10, 2006 | 02:36 PM
cobb's Avatar
Car: 90 camaro
Will a c5 master fit up to a third gen?
Old Mar 10, 2006 | 11:08 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
The boot around the operating rod is differant and won't fit the hole in the firewall. If you trim the boot or the firewall it will fit. The master cylinder will bolt right in place of the thirdgen one. I just used my stock booster and a 4th gen master. However the lines from the master to the proportiong valve didn't fit right so I had to get new lines made.
Old Mar 11, 2006 | 12:17 PM
cobb's Avatar
Car: 90 camaro
would you have any part number for the lines, and pic of the install.
Thanks Cobb
Old Mar 11, 2006 | 03:16 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
here's a pic of the proportiong valve and master. What I did was bolt the two together and send it to classic tube and ask them to make lines. I got stainless lines and it was about $30-$35.
Attached Thumbnails will a 4th gen master AND booster swap right into our cars-img_1983-large-.jpg
Old Mar 14, 2006 | 06:22 PM
cobb's Avatar
Car: 90 camaro
would you have a pic of this done yet and was it worth the work?
Also how long are those lines ordering flexible ones would be easier on me.
Old Mar 20, 2006 | 09:25 AM
cobb's Avatar
Car: 90 camaro
Has anyone else done this swap?
Old Apr 14, 2006 | 05:58 PM
deracer's Avatar
Car: 91 Z28
Transmission: TKO 600
I'm in the process of doing this swap. The break booster will not fit without modification to the firewall. So far I've made a template and will start filing on the firewall as soon as I pull back the carpet (my car is already completely apart). I'm going to try and bend the lines myself, and cut the current proprtioning valve in half then attach an aftermarket porportioning valve for the rears. I'm sure there are many people ot there who have done this, or something similar. Will let you guys know how it goes.
Old Apr 14, 2006 | 11:28 PM
Blue1989RS's Avatar
Car: 1989 RS
I got mine all good! I put a wilwood prop valve in and now the car stops HELLA fast. From 35mph it will stop in about 2 car lengths!
1992rs/ss
Jan 31, 2025 05:10 PM
midge54
Dec 27, 2019 04:14 PM
AkDrifted
Aug 17, 2015 07:45 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
