Rear Brake Bracket Bolt 10112649
Old Nov 25, 2024 | 11:40 AM
L98 Z28's Avatar
Car: '92 Z28
The torque-to-yield rear brake bracket bolt GM part #10112649 is discontinued. Is there an alternative that can be used other than just reusing the old bolts and hoping they don't fail? I can't find any options searching the forums. This would be for a 1992 Camaro Z28.
Old Nov 25, 2024 | 05:30 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Rear Brake Bracket Bolt 10112649
Go anywhere that sells fasteners and get some nice grade 8 bolts
Old Nov 25, 2024 | 06:10 PM
Beeman's Avatar
I'd use some blue loctite on the old bolt.
Old Nov 25, 2024 | 09:25 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I've never had a problem reusing them.
Old Nov 25, 2024 | 10:08 PM
thatsupnow's Avatar
Was torque to yield bolts even a thing in the early 90's?? I thought that came later on??
Old Nov 26, 2024 | 07:26 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
...mostly.
TTY bolts were definitely a thing in the '90's....and long before that. However, they weren't much of a thing on domestic cars of the 90's and even less so, on brake caliper brackets. I'm 99% sure those bolts are not tq 2 yld. I agree with "thatsupnow", that you can simply buy a grade 8 bolt, or a 10.9 if it's metric and use it...and it will be way better than good enough for that application.
Old Nov 26, 2024 | 10:22 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Was thinking same thing. Seems like this would be something GM would try to avoid as a design feature to keep their cars easy to work on.
Old Nov 26, 2024 | 02:02 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Before attaching the term TTY so readily to any "get new bolts!" application, keep in mind, a TTY bolt has:
A reduced diameter shank between the head and threads.
That must be equal or smaller than the thread minor diameter.
And then, they are designed to stretch beyond ever being the original length.
Sincerely, learn how to inspect your bolt fully, and re-use it with confidence. It's not TTY.
There are several factors the unwashed internet believes make a bolt TTY, which are not qualifiers. Maybe I'll list them later.
Old Nov 26, 2024 | 03:18 PM
L98 Z28's Avatar
Car: '92 Z28
The service manual does say to use new bolts and allow the adhesive to dry. Checked the bolt head and they are marked as 10.9 bolts, and they do not have a reduced diameter shank. I'll loctite them and reuse them. Thanks for the replies.
Old Nov 26, 2024 | 03:44 PM
Engine: LT1, L400
Sounds like they want the thread locker on there, hence "new bolt", that come coated with thread locker already on there. Not TTY though.
raptere
Brakes
22
Aug 20, 2022 02:49 PM
Coolfrog3000
Brakes
Mar 13, 2021 07:01 PM
Twin_Turbo
Dec 11, 2011 08:15 PM
RMK
Brakes
Apr 18, 2011 02:10 PM
91formulaNY
Apr 16, 2010 05:40 PM
