3/8-24 to 14mm?
Old Aug 18, 2025 | 08:24 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
3/8-24 to 14mm?
I'm trying to install a Wilwood proportioning valve and can't find an adapter anywhere. Anyone have any ideas where I can source this adapter fitting? It would appear that the Edelmann 262015 everyone has used in the past is currently unobtanium. So far, I've only been able to find 12mm adapters.
Old Aug 19, 2025 | 04:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 3/8-24 to 14mm?
Are you trying to adapt to the 14mm nut on the brake line or the female port in the prop.valve?
It sounds like the nut. I used a 14mm 1.5 coupling, and another 14mm nut that I drilled and tapped to 1/8-27 npt then screwed in an adapter many moons ago
Old Nov 22, 2025 | 07:18 PM
Anti-Venom's Avatar
Axle/Gears: BW 3.23
Re: 3/8-24 to 14mm?
Rock Auto ended up re-stocking one single fitting. Pretty sure I ended up buying the only one available in the country. lol
Old Nov 23, 2025 | 11:37 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: 3/8-24 to 14mm?
Originally Posted by Anti-Venom
I'm trying to install a Wilwood proportioning valve.
cut the brake line, make a new one, add the fittings of your choice for ends.
Moonlight137
Aftermarket Vendor Review
Oct 10, 2019 05:21 PM
az_brent
Brakes
May 27, 2007 01:27 AM
rsn932
Brakes
Mar 30, 2005 06:16 PM
CamaroFreak87
Feb 23, 2004 05:51 AM
