cant find a proportional valve
Old Apr 28, 2007 | 04:12 PM
az_brent's Avatar
Car: 1985 firebird s/e
Engine: 388ci stroker
Transmission: stock, t-5?
i have a 85 s/e bird and it has 4 wheel disk breaks. I'm trying to find a new proportional valve but I'm told it is discontinued. anyone have any suggestions on where to look to find one?
Old Apr 28, 2007 | 11:26 PM
brad_26's Avatar
Car: 1984 camaro
Engine: 2.8l to 383 stroker
Transmission: t5 to th400
Axle/Gears: 12 bolt soon with 3.73s
Re: cant find a proportional valve
y not just got aftermarket with a wilwood or russell if it will fit ?
http://store.summitracing.com/egnsea...918719&NeXID=5
Old Apr 30, 2007 | 02:11 AM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
Try ebay and type in GM Proportioning valve.. i have the same problem, i've called every source i could possibly think of and NOBODY has one
Old May 6, 2007 | 08:03 AM
Eightyninef's Avatar
I have a new one in my basement. It's the 1LE design.
let me search....
Old May 25, 2007 | 10:14 PM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
I just ran into this problem myself. I haven't called napa, but no one else has them. I may just put an adjustable one inline after the rear section.
Old May 26, 2007 | 12:33 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Autozone lists two valves for 1985 Firebirds, under the part name "Master Cylinder Kit" Part # 22232 and Part # 22351. I suspect one is for the 4 wheel disk setup and one is for the disk in the front and durms in the rear. I can't say that they have it in stock, but they indicate you can buy them on line. NAPA may have it also. So take a look and maybe you will be able to purchase what you need from them or another vendor.
Dve
Old May 26, 2007 | 12:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i bought one from my local gm dealer about 6 months ago, brand new 1le. i would not recommend it though because of the preemo price you pay at the dealer for "GM" parts. i was just tired of searching for one and needed it yesterday, so i just got it there. i think it was something like $115 , which is absurd
Old May 27, 2007 | 01:27 AM
RedLava's Avatar
Car: 86 z28
look in the junk yard they are easy to find almost no one who grabs a disc rear off a car grabs the proportioning valve as well.
edit whoops sorry did not realize that you wanted a new one
deracer
Apr 11, 2016 12:04 AM
gta90
Sep 15, 2015 04:00 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
