will everything hook up as normal?
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
i'm putting a j65 g92 rear from a 90 in to a drum rear 90. will all the brake lines connect like before? will the master cylinder/booster have to be changed as well?
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: will everything hook up as normal?
The brake hose and the e brake cables will be fine. The master and booster are fine. You will need to change the proportioning valve.
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
thanks dude... so the rear brake lines arent different because i know the earls ss kit has two versions
Car: 1990 Formula
Engine: 95 LT1
If you have the rear end with all the lines you are set. The Earls kit is different because there are two additional hoses for the calipers.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Really only one for your application, 89-92 four-wheel disc (I suspect the other you mention is for the four-wheel disc 1LE version):
http://www.spohn.net/category.cfm?categoryid=1095
JamesC
JamesC
Linson
Oct 1, 2015 09:50 PM
